Possibly, I might even have the plugs you need for the transmission, as I converted my harness from auto to 5spd.
You'll have to wire the clutch start to the nsw on the transmission, it's the same thing anyhow. Then just run the control wires from the transmission to the ECU. If you want post up some pics of the plugs on your transmission wiring and I will check to see if the plugs I have match.
