Help... Wiring 1JZ stuff.....
Datsrboi
Loud pipes Save Lives
Jul 31, 2007
797
Haltom Texas
I got all post here fixed but now have more...
Updated-
I need two things confirm just extra in case..
Some wire in diagram are different color from the actual harness.. So I just still connect them or are they really in the wrong place? Its just like 4-5 wires..
Two. Very very scary.. On the diagrams JZA70 IH2 wire number 18 (II1 #13 a/c amp) AND JZA70 IH1 wire number 11 (a/c Amplifier) plugs into MA71 B1 plug number 13.... Do I tap both to it?
OneJArpus
2,798
I will try to be as much help as i can, i just did the wiring on my 1j swap. I'm having a hardtime routing the wiring harness through the dash w/o pulling it.
Question, i see you went in through the driver side. How did you get it across the dash? w/o taking the dash out?
#1---THE ECU
all #'s = body plugs IIRC, i got an extension done through driftmotion. Not sure how to wire it up myself though. You will need the 7M plugs for the plugs on the dash (male) and make a jumper harness with the female plugs of the 1j harness to connect them
#2---THE POWER SUPPLY
use the 1J's wires throw the 7M away but switch to new terminals
#3---Alternator...
4. = Alternator wires. The 2 black wires i believe are the "POWER" wires. Get a wire and run it across to the battery
? = connector for the back of the alternator (i believe looks like it)
#4---Heater bypass valve plug
i believe this is correct. What i did was extend the plug on the p/s of the vehicle to connect to it
#5---The fuse box area and wires
3 = EA2 connector. You will need to wire up the alternator, fuel, etc there.
#6---Turbo pressure sensors
this should be on the wiring harness. I will try to get pics of mine so u can see the location of it
Check this site out for wiring diagrams
http://web.archive.org/web/20051227170957/www.1jz-gte.us/
mobes
Supras are never 'done'
Bozeman, MT
The info is out there. The diagrams tell you everything you need to know. If you're not electrically inclined, this may not be a job you want to handle yourself. By the sound of your questions, you may be in a bit over your head. We can try to spoon feed you, but if after reading this it still doesn't make sense, please, for the sake of your car and your own safety, either get help from a friend who knows electrical, or take the car someplace that does. If you're not comfortable/experienced soldering and were planning to use crimp connectors, please enlist the help of someone who can do it properly. I'd hate for you to put in all the effort and either not have the car run, or worse, cause a fire.
#1 ECU
In the first pic, the #1 pink plug connects to #1 green. The rest are 'body plugs'. Do you have the mating 1JZ connectors (besides #4 in the pic) or your old 7M engine harness? You'll need at least one full set of mating plugs from either car. If you have both sets you can make a jumper harness, otherwise, you're going to have to transplant one set of plugs. In both cases, follow the aforementioned diagrams.
#2 Power Supply
Move the wire from the 7M + terminal to the new one. Honestly?
#3 Alternator
You can join them, or just replace it all the way to the stud. There are two similar wires from the 7M alternator (#4, second alt picture). That is where they need to connect. Easiest IMO is to run 2x 8ga from there, under the radiator support with the existing wires, around the battery, and to the fusebox, where you'll attach the other ends to the 7M alt wires. The plug needs to be wired to EA2, #3 in the fuse box picture, according to the EA2 diagram on either of the sites linked previously.
#4 Heater bypass - correct.
#5 Fuse box - #3 is the EA2 plug. You don't need the rest (someone may want the fusebox). You'll wire the EA2 plug to according to the diagram.
#6 Pressure Sensors
One looks to be the gauge sender, the other the MAP sensor. You only need one. The one without the wires and blue tape on it in the pic. There should be a spot on the harness at the back of the intake manifold for it to plug in to. It gets vacuum source from a port on the engine side of the intake, with a screw in black thing. The screw in black thing is a filter.
Between what TaSe and I stated, that about covers it.
OneJArpus
2,798
#1 ECU
#2 Power Supply
#3 Alternator
#6 Pressure Sensors
Correct, try and get a friend to help who knows what they are doing. I had help with mine, that is the only reason why I know what they are, plus i did them this past weekend.
I stress that this is something you do not want to take lightly and it MUST be done correctly the first time or it will be worse in the end.
Learn about electricity
http://ask.metafilter.com/32514/Lea...nd-colorful-but-not-completely-dumbeddown-way
Click here to learn how to read wiring diagrams
http://www.ehow.com/how_2090373_read-wiring-diagrams.html
http://www.answerbag.com/articles/How-to-Read-Wiring-Diagrams/3aed7851-7484-7255-a8b5-03bee2ccafb5
Datsrboi
Jul 31, 2007
797
Haltom Texas
Thank you guys. Yeah I got a it figured out. It helps when you print all of the pages out rather just looking one at a time. Printing all the main pages and laying them out helps a lot.
Datsrboi
Jul 31, 2007
797
Haltom Texas
Updated-
mobes
Bozeman, MT
Which wires specifically?
http://www.supramania.com/forums/showthread.php?p=936011#post936011
