help supra down!!!!
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
Well it started by not idling it sounded like it was misfiring and missing when i turned it on. Then i wouldnt stay on on stop lights i would just turn it one and give it gas to keep it on, when i got to walt mart it died and wont turn on now. the pump is working , i got spark , i adjusted timing and fuses in the engine bay are all good what else can i look for im heading back in about an hour to check sensors any advise would be appreciated......:1zhelp:
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
no codes at all the engine light is off and like i said there is spark , fuel pump is on there is pressure on the Aeromotive fpr whats next to check for
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Timing belt?
When my timing belt went, the engine would crank over all I wanted but it would never catch. The clue was that the tach stayed at a flat zero while it was cranking.
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
Its not the timing belt every belt seal on the car is new i just rebuilt the engine and head and replaced every seal and belt it has 1000 miles since rebuilt i cranked it for the first time on christmas eve.... i dont know were to look for im gonna go and check every sensor with ohm meter specially my cps that might be the damn problem what so u think???
st2b
589
Versailles (Lex) Ky
1. Check Mass Air Flow Sensor
2. Check Throttle Position Sensor
3. Check the plug wires (Make sure they are in the right spot, and make sure they are ALL the way in the cylinder head)
4. Check the fuses in the drivers side kick panel
5. Check the amount of energy left in the battery (Volts)
6. Check to see if you have gas (Obvious)
7. Check to see if there is any coolant or something in your plug galley, this will cross sparks and cause this to happen.
8. Check all other sensors and plugs and fuses.
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
k ill do that too, now that u mention that i jiggled the harness close to the cps and it kind of wanted to start ill chek the wires tomorrow along with the sensors. Im gonna go ahead and pass through autozone and get a volt/ohm meter to check the sensors resistances ....
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
IT LIIIIIIIIVES !!!!:naughty: Yeah i just got back with my car from walt mart. The belt tensioner bolt was loose so the cams were not aligned. I re aligned them and tightened bolt to 36lbs, adjusted timing and she started first try. What a relief and i also found out that my failsafe thermostat was stuck open wow. I went back to orielys and told em if it has warranty and thet said no because THEY DIDNT PUT THE WARRANTY in my account. So i got a new one Its a Moto Rad Failsafe part # 7240-180 thats the one i got and they also sell the # 7240-195 the 160 is special order they are $12 dllrs but well worth it..Thanks to everyone that helped ....Problem Solved :icon_bigg
