do the springs(part sticking out the most) go in toward the flywheel or toward the pressure plate. The disk I have says flywheel side on the flatter side, but the clutch won't go in this way. This is a fidanza flywheel, ACT pressure plate, new stock throw out bearing and a new stock disk....
If turned around correct by the writing on the disk, the center hub of the clutch hits the center of the bearing and the disk sits about a 1/2 inch away from the pressure plate friction surface, if I turn it around and put the deep part with the springs in toward the flywheel, it fits perfect. I HAVE to get this thing back together tomorrow.
