Help please!!!!!
utsupraguy1010
utah
Alright up until friday my car has never had a problem starting at all ever. And some how out of the blue it just has a really really hard time starting. I turn it over and it tries really hard to start but will not kick over. After trying for a long time it will start but only if i give it gas and make it idol at 1200 rpm then i can let it sit for a bit and then drive it. I did the jumper check that the chilton book says to do. And it did start to make the sound of the fuel pump. But if i do not do the jump test and just turn the key over the fuel pump does not make a sound at all. Is that a sign of a bad fuel pump. I have codes 14, 42, 51, 52. 14 is a ignition signal but i dont know what to check with that.... PLEASE HELP i have work in the mornings and i cant miss work have to fix today... Thank you........
