Hey folks,
Swapping a 2JZ-GTE from an Aristo into my mk3 supra. Thinking about keeping the stock twins for now. few issues we've got right now are:
1) BIC Motor mount brackets seem to use a different set of holes on the right hand side? Did I buy the wrong kind of BIC brackets? Tried reversing the brackets, but they don't fit at all that way.
2) On the left hand side, the larger diameter turbo drain back hard line fouls on the BIC motor mount. Did others just cut the hard line further back? It doesn't seem very receptive to being bent.
3) I've deleted the hydro fan, and put on a water pump from a mk4 supra TT. Is there somewhere that details wiring up electrical fans? I'm assuming this is what it needs.
Thanks so much
Thanks so much
