Start with your 100 amp fuse in the fuse box under the hood. It is not a pull out fuse. It is bolted in so don't try to pull it out without taking the bolts out first.
its not the fuse u just put in a new one and i don't know how to use a volt meter plus the previous owner cut up a bunch of wires on the harness and even by the ecu im problably just going to get a new engine harness anybody have a good condition one for sale?
i think ive found the problem the small cable from the + battery i cut it open and it had been torn as is stretched to far and had no conection the the wires so i'll fix that and see what happens
well now ive found another wire it comes off the same small wire that clamps on to the positive terminal and its been completely cut and i don't see were its from any help
