hey everyone looking for some help or tips on my new car. i bought it already built but with some tuning needed. Here is a list of upgrades all with less than 500 miles. Engine was pulled and a rebuilt JDM was installed. 1mm over bore, ground and polished crank, block decked, new pistons, rings ect. Head was rebulit with new valves and springs and a high flow valve job done. head was also decked and a steel shim gasket installed. Fuel injectors upgraded along with the fuel pump and a adjustable fuel guage. A lexus AFM and a blitz air filter and blow off valve. The turbo was machined out to accept a T-60 cassette, coolez inter cooler piping. It also has a double stainless steel down pipe conected to a HKS super sport exhaust with test pipe
ok heres my issues. the car runs great and pulls hard if driven normal and boosted moderately. if you free rev it or push clutch in after hard take off it will stumble flash ses light and then stall. if you tromp the throttle it builds boost and cuts out or if the boost goes above the 8psi the fatory guage reeds it cuts out. finally when boosting in 4th and 5th the ses light comes on at times. idle is right around 1200rpms which i think is a bit high.
the car has a hks fcd but not sure if its working. i have tried all the settings in 3s and nothing has changed. 0-3-6-9-12. it is also wired up for an aem tru boost which is not working either at least the guage is not working.
thanks for any input you may have. I have already checked the intercooler piping for leaks and none found.
