bigboostinmk3 said:
A few months back I purchased a 89 supra (7mgte) for $300. The car is currently not running. It has about 2-3 lbs of pressure. I thought for sure it would be the pump and I put one in it and new filter and its still doing the same thing. The car will start if u feather the gas when u crank it. It tries to idle @ 700-800 rpm. If u hit the gas it will back fire once in a while and it stalls out. U can hear the turbo charge up and blow off. I checked the voltage to the pump and its good. Someone told me it might be the ECU, but Im not for sure. Has anyone had this similar problem? Am I stuck with a bad MK3? Someone please help.:1zhelp:
From your post I am assuming you are a fairly competent mechanic... so with that said. If you are only getting 2-3 lbs of pressure, my first step in diag would be as you stated the pump. Also check for a restriction in the pressure line to the rail, also have you checked the FPR??? they are a diaphram style regulator and can burst, causing fuel to come out of the vacuum port on the regulator. Pull the vacuum hose off check for fuel coming out of there. If ther is no fuel coming out. Pinch off the return line, then check your pressure, could be that the regulator is hanging open. if nothing there, hook a volt meter to the Fuel pump pos / neg have someone try to get the turbo to build pressure, watch the voltage as it hits boost. If i remember right, it should raise the voltage a little bit. If not check your boost pressure sensor or posibly the ECu as you said. hope that all helps. And for the hell of it verify the ground for the pump. turn your DVOM to the Mv scale black lead to neg. batt post, red lead to the fuel pump ground. anything more that say 50mv should be cleaned and or repaired. have fun good luck..
