help me please
JNasty
i drive fast cars (supra)
Jun 25, 2005
358
Jacksonville fl
if i go 1mm oversized on the valves with a 3 angle valve job would it be worth it, or should i just get the valve job? im going for 500rwhp.
also should i get the head ported and polished? would it be worth it aswell?
if o go oversized with the valves what else would have to be upsized? would the stock cams run oversized valves ok?
Yellow 13
Lurker
Apr 4, 2006
2,308
Fairfield, California
You should redo your whole valve train and do the 3 angle valve job with those HP goals IMO.
Stock cams are fine. Just make sure the shop gets the clearances right.
JNasty
Jun 25, 2005
358
Jacksonville fl
yeah im going to redoo the whole valve train and the valve job but should i go 1mm oversized or just stay stock with the valves
jdub
Feb 10, 2006
10,730
Valley of the Sun
IJ. said:
I did the whole 9 yards on my head..
Is it worth it?
I think so but cost will be a factor as quality work isn't cheap.
Same here...head flows better, but it's not cheap!
