Time to look at the wiring if you want, I can help you make sure all wires are connected where they're suppose to be, maybe something is just not hooked up right, also check ground, and any terminals at the battery. I was able to drive my 1JZ car and when I got under full boost the car would turn off and nothing would work, found out the wires was frayed there.
TPS is all good too?
