this may be long so please bare with me..ok ive been going at my car for 3 days now and no luck what so ever i may not be doing everything correct thats why i need help..ok first off the problem at hand i got my car back from the shop after they replaced my headgasket and put on a brand new cylinder head and brand new seals throughout the entire engine..they also rebuilt/replaced my ECU and repaired damaged parts in my wiring harness it still is a little fraid and old in places but what can you expect from something so old...anyways when i get it back i turn on the car and i get this incredibly loud hissing noise from my intake side around the rear fuel injectors(it sounds like)..i tried to feel around to try and feel air because youd think that loud of a sound air would be escaping in large amounts but no i felt no air..so i thought maybe my gaskets were bad or the intake manifold wasnt on tight enough so i take it off and replace the gaskets and also put sealant on them and tighten each bolt as tight as they should be put everything back together and also while i did this i replaced every single vacuum line as well thinking it couldnt hurt..once it was all back together i turned the key the hissing is still there and it still stalls farely easy/almost right away it also backfires everyonce in a while..so then i decide to run a diagnostic on it i got codes 21,51,52,41...the sensors it said to replace were the 02 sensor, water temp sensor and throttle position sensor..so i replaced all those except i have to wait till tomorrow to get the 02 sensor they had to order it..i figured the throttle position sensor would fix it but it actually made it worse i hit fuel cut at 2k rpms and then it will die..i heard you need to calibrate the tps but im not really sure how to do that at all i think that may help but i dunno..it also said and i read that my egr solenoid may be bad so im hoping ill get that in tomorrow too cuz that may be were the leak is from i dunno..could bad fuel injectors make that noise cuz it seems almost directly on them?..but if anyone has any idea or wants to help me out if your local that would be greatly appreciated this is my only car being that i am still a kid so i need it so i can get around to school and shit...thanks in advance
