Help ! Low budget horsepower...
raymi
Slow is not an option !!
Dec 26, 2005
56
Puerto Rico
:icon_conf Hey wats up ! Merry Christmas to everyone ! I am new here and also to the world of Supras ! I recently purchased a 1987 Supra non-turbo version, but with a new 7mgte Turbo engine straight from Tokyo Motors with an automatic trans in it ! I bought it like that...the engine only has 75K on it. I am in the process of expanding my home and my money is all accounted for, but I want to know if anybody can give me some tips of how to gain the most horsepower using the factory components for now, so I can have a little fun with it ! Thanks for your help and I hope I here from you soon !!:icon_bigg
robbo185
693
Chicago
you can get a manual boost controller from dr. jonez for like 25 bucks. turn up the boost abit.
get a test pipe for like 40 bucks.
raymi
Dec 26, 2005
56
Puerto Rico
Hey thanks ! Anything else you can think of ? How much boost can I go up to without hurting the engine ?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
First up, you'll need some basic maintenance, or you'll be sorry. Fluids, hoses, seals - check as many as you can.
After that is done, new intake, 3 inch exhaust from the back of the turbo all the way out, and then buy a boost controller and crank it up until just before you hit fuel cut.
robbo185
693
Chicago
well it all really depends on your budget.
you can get a K&N FIPK intake for like 140 bucks
cat back exhaust for 300-800 buck
bic downpipe for 200 bucks or so
also i would invest in an aftermarket boost gauge so you can tell how much boost you are actually running. Thats about 50 bucks
but most importantly....as most people will say on the forums...make sure your car properly maintained. Check all the vacuum lines, change oil, check fluids...etc...etc
raymi
Dec 26, 2005
56
Puerto Rico
Thanks ! If you remember anything else let me know !
raymi
Dec 26, 2005
56
Puerto Rico
Thanks, let me know if you remember anything else !
raymi
Dec 26, 2005
56
Puerto Rico
s383mmber1 said:
isn't there a sogi air intake mod? You could hollow out your cats, or buy a test pipe.
My car has a 3" exhaust with no-cat all the way back and a Magnaflow 3" muffler, its also an automatic but with a naturally aspirated rear end (higher gears) !!:icon_bigg
supraman7mgte
Shut up,bitch!!
Sunny California
yup,replace all fluids,tune up,replace the MHG with a new w/ bolts,replace the front seats w/lighter ones,same w/ the spare,K&N drop in filter,replace ALL belts,change the air in your tires,and run 91 octane fuel
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
I have the same rear end... and it sux for gas mileage... plus you can't drive on the highway's hardly at all...
boost fiend
852
Rockford, Il
1. back the screw out on the stock afm housing
2. shim the wastegate
3. 3" exaust, no cats(high flow cats if the test in your area)
4. good tires.
first and formostCHANGE ALL YOUR FLUIDS. REPLACE HOSES. FIND THE BUGS AND WORK THEM OUT!!!!.
thats a quick start.
as far as air filters, use the apexi at suprasport.com. flows better and dont clog afm's either.
