HELP!!!...Installing an after market "Y" downpipe on a 1jz.
mk3supraoz
133
So. Cal
Like the title says how do you install a y downpipe on a 1jz? do you have to take one of the turbos out? HELP!!!:1zhelp:...this may be a stupid question for some of you, but im new to 1jz's.
thank you for your help,
mk3supraoz
chuckmuska2005
265
canton
I took both of them off of the manifold and installed them individually onto the y-pipe. reconnected my oil and coolant lines and hooked up my down pipe. Trust me, it's no where near as easy as it sounds.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
That's the best way to do it. You can do it by removing only one turbo, but it makes it very hard to get all of the bolts.
If you have access to the proper equipment, hoist the engine (or jack up from the bottom), so that it's sitting as high as possible in the engine bay. This will give you some more clearance to get at the turbos.
mk3supraoz
133
So. Cal
Thanks. yeah i notice when i was looking at it that it was not going to be easy. about how long would it take?
mk3supraoz
133
So. Cal
Kaneda1jz;1160892 said:
Heard it takes around 5 hours to take it appart, and about the same time to put it back together. Here's a link that might help you: http://www.thepointnet.com/Lenticular/Turbo/
I'm planning to do the same job on mine this winter, so keep us updated on how it went and difficulties you encountered.
Good luck!
damm thats a lot of work for a dp...oh well:nono:
i plan on doing it on eigther saturday or monday, hopefully it all goes well.
Ill let you know how it goes, the things we do for those extra pony's:naughty:
mk3supraoz
133
So. Cal
chuckmuska2005;1161185 said:
I took about 2.5 to take off and 2 to put back on so yea I guess I took about 5 hours to do everything.
hopefully i could bust it in that time, ill try to get a buddy or my pop's to help me out
Kaneda1jz
10
Montreal, QC
with the engine in or out?
also do you have any precise data on the power increase?
terror
Antibliss
Jun 13, 2008
242
Alaska
hey guys i have the hks y pipe and i was wondering if that aftermarket ebay one is much better or what, didnt want to start a new thread, thanks
terror
Antibliss
Jun 13, 2008
242
Alaska
sorry cant make pic smaller
chuckmuska2005
265
canton
I ran the Ebay one. It fit fine and I did it with the motor in the car. ( very difficult to get the oil and coolant lines off the rear sectioin.)
