help if you can
HpLover101
4
salisbury,maryland
hello i was wondering if some1 could tell me how to turn the boost up on my stock ct26 without a boost controller and if u can please tell me where it is and how to do it
loki2043
645
Portland, OR
new intake and exhaust. that will raise it a few psi... cheaper to buy a boost controller... or pop some washers in the wastegate.
shaeff
Kurt is FTMFW x2!!!!
10
Around
ok. i'm like IJ. i don't tell people to search. but, the information is all over this site. if you have a basic understanding on how the turbo system works, then you should know that we have wastegates which bleed off pressure as boost increases, starting to open very low, and bone stock, being fully open at about 6.5psi. i typed in the exact following:
ct26 wastegate shim
and got this thread as the FIRST listed out of two total.
http://www.supramania.com/forums/showthread.php?t=4301&highlight=shim+ct26
and this was the second:
http://www.supramania.com/forums/showthread.php?t=1515&highlight=ct26+wastegate+shim
both explain how to do what you described.
now, if you DON'T know anything about the turbo system on our cars, then i HIGHLY suggest you ignore the information i provided, and SEARCH, A LOT, before doing ANY power modifications to the vehicle.
it is imperitive to understand how a system works before you try to alter it, as the end result could be catastrophic to both you car/motor, and/or yourself.
happy boosting,
-shaeff
countdown to next BHG thread in 3...2...1...
happy boosting,
-shaeff
Even when you do know what you're doing there are no guarantees ;)
shaeff
10
Around
yes, for a while i was running a dr. jonez mbc, but i now have a greddy profec b, which will be replaced by the maft pro's boost control feature (hopefully next week!)
-shaeff
