Help identify parts (pics provided)
OneJArpus
2,798
Sup, i need help identifing some parts.
I have no clue what this is
Anyone know why theres a threaded hole here??? I seen it taped up
One of the nipples was broke on my this part of the power steering. I changed to a new pump but i want to make sure if this will effect everything.
Also, i am not sure what this thing is. I notice it when i was going to install my BIC mounts. It lines up with the two back bolts of the mount. Do i need this?
c_ronius
1jz 4Runner
Jan 2, 2007
109
Tampa, FL
www.rsworld.com
The thing on the oil filter looks to be a aftermarket sandwich plate for running an external oil cooler.
The thing on the power steering is the idle-up valve for the power steering, it allows the engine to idle-up a little when the power steering system is under load.
The thing which attaches to the engine mount is the fuel pulsation dampner.
OneJArpus
2,798
Thanks!
One of the nipples on the valve is broken. Could i get a replacement somewhere?
Do you know where the fuel pulsation dampner goes?
Sweet didn't know i had a sandwhich plate thought it was "stock" lol. Could i get an adapter for an oil filter relocation on it?
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
1) Your co2 canister goes to vent line of fuel tank.
2) Your oil/water cooler with maybe a plugged off sandwitch plate hard to tell.
3) Your power steering idle control valve.
4) Another angle of your power steering idle control valve.
---------------BreAK---------------------
5) Yur pressure fuel feed line for your injectors with your pulsation dampner in the middle of it you need it for a factory 1JZ setup.
S
Supracharged88
Guest
on my chaser motor there is a fuel filter where the Fuel dampener is. do i need to switch that out or is my stock set-up fine?
Van Diesel
Powered by vino
Dec 12, 2006
396
El Paso, Texas
Picture 2 is a sandwich plate for oil temp/oil pressure gauge. The top port is already blocked off and is used for oil pressure. The bottom port (open) is a 1/8 NPT. Get a 1/8 NPT plug and some thread tape and your done. Maybe $3 in parts.
