ok im on the last part of the head gasket i have to make sure the cam sensor is in perfectly is there any trick to make sure that it is in properly? thank you
just line up the marks and stick it in.thats the dimple thats on the gear and the notch thats on the housing. with the engine at tdc of corse. and if you didnt bother to clean off the dirt that was on it you would still be able to see where the mounting bolt was.
ok job all done car runs mint at an idle kinda, soon as you drive it and it hits boost it fricken bucks like a bitch! i pretty sure its a vaccum leak but ihave no clue were to start looking to fix it? any suggestions...
