help electric fans wiring!!
harley1985
117
killeen tx
http://www.fordmuscle.com/archives/2003/02/electricfan/index.php
thats all i could find good luck. the link above shows a way to do it, but i think a good thermostat switch would work fine. i would run a straight hot to the battery (fused of course, at least a 60A DC) and the thermostat switch on the ground wire. not sure how to mount the thermostat switch other than tacking a bung into the radiator. perhaps you could fit into the radiator drain cock? if anyone else would like to elaborate on this i would be grateful. im thinking of doing the ford contour swap.
