Help! Big idle problem!
supra4ever68
105
Anaheim, CA
My supra just dies after i floor it for some reason...it has been doing this since forever and i have adjusted the tps and rewired the new knock sensors to remove code 52 but it still just dies after i floor it....any common problems with this??? please help! i need her running perfect or almost perfect in a month
pejay
15
madison,wi
might be your bov..i have a blitz bov and it does the same thing..reroute the air thats released by the bov back to the intake and you should be fine
pejay
15
madison,wi
the bov is releasing meter air..so when you let off the gas your running rich which causes the car to stall a little..but in my case the car just dies..
supra4ever68
105
Anaheim, CA
well there is a hose that i just have connected to a bolt on the valve cover....it is coming from the top of the og bov...should i just let it hang out freely??
pejay
15
madison,wi
that might be your problem ..you should plug that hose back to where it was and that might fix your problem..
