..ok here i go please read in full...
ok ill start with the owner i bought this car from didnt take care of it..i got it with a cracked casing in the turbo so it was slightly smoking but bairly, could hardly tell..he gave me another turbo to swap it with..i got home and did that but it didnt boost later my entire exhaust system literally fell apart and off my car so i replaced my entire exhaust system it killed two birds with one stone..i got a new system and i was now boosting..the stock downpipe restricted my car that bad and didnt let my turbo spool..
anyways that same day after i finally got boost i wanted to feel the power that i hadnt yet..so i took it out that night ran it slightly hard not too bad cuz i didnt quite kno my car yet..and right away got a BHG it was probably already blown but i noticed right then cuz it was overheating/stalling and smoking it was really bad..the next day i started to do the job of replacing the headgasket i went through the whole process but i just used stock parts..when i finished it was leaking like crazy and still smoking..my problem wasnt fixed..the head itself was cracked..
so i took it to a shop to do the repairs and headgasket job but with a greddy MHG and arp studs and completely rebuilt cylinder head this time...they completed the job except they didnt use the HG or Studs that i gave them cuz there ass holes also i had it towed back because they forgot to put the cam seals in and i wasnt gonna pay more to have them do that so i did that...i did that adn then drove it, i literally pulled it out of my driveway and BOOM i heard a big bang and then no power and stalled..
my turbo blew i had no boost nothing..so i took it in my garage and replaced it with the turbo that was on the car in the first place when i got it despite the fact it burnt oil..drove like that for a while..i then decided to replace the turbo and might as well do a turbo upgrade so i bought a t4 manifold garrett ts04 turbo and hks standard wastegate i also made a custom o2 housing to fit the turbo..anyways i did the swap and thought my issues were fianlly over..nope..
i had boost but it felt like i was hitting fuel cut around 2500-3000rpms it also seemed i was running on less cylinders..it was like getting pushed back with the same force as i was producing everytime i tried to excelerate..the bov also doesntt have its old pshhh but a sputtering psshh it sounds like compressor surge...i kept doing little things..lowering boost in case i was hitting fuel cut..replacing vacuum lines and hoses..and things like that hoping it would help it didnt.....
the car eventually started smoking like crazy under acceleration but would go away while i was cruising but still with no power..i thought i had another BHG, i have codes for turbo charger pressure, 02 sensor, and knock sensor ..im starting to think that im getting blow by due to the lack of power and it smoking like crazy so this is what i was planning on doing..replacing the piston rings on all 6 cylinders and using an HKS MHG and arp studs..let me kno what you guys think the problem is..sorry about all the info..
the real poblem now that im trying to figure out is in the bold..the rest is just background..i need any help i can get..also i kno it cant be my valve stems seals that are burning oil or whatnot because there brand new since i bought a completely rebuilt head for my headgasket job....
y does it feel like im hitting fuel cut/getting no power and burning oil..o yeah my coolant is also brown lol it seems oil is getting in it..so yeah thats my problem i think i got it all if you have questions ask..thanks..i need this thing back on the road!!!
