i really need some help guys!
i have an 89 supra 7mge-t
blew the motor
dropped a 7mgte back in the supra
everything is hooked up besidess
there is a ground which runs with the starter ground cable but its a little bit shorter..
where does this connect to?
boost line.
a boost gauge was installed in the car when the 7mge was turbo charged
the boost line runs from the a solenoid on the passenger's side of the firewall to a T which run to the boost gauge in the car
i just dont where know to connect the 3rd park of the T on the engine
lasttttt but not least there is another thick ground cable from the bottom half of the blow on the intake side. i believe this is a (-) ground which connects to the (-) terminal. is this correct??
any help would be appreciated!! im so close to getting her back up and running. i just want to make sure everything has the OK before i try to crank her
blew the motor
boost line.
