help 350 swap to supra
supramk3man
414
kentucky
ok guys i know most of you all hate the ideal of a sbc going in to a supra i don't need to know you hate it i just need to know if any one has done it and can help me on how to do it. I have been around supras for the past 6 years and owned over 26 supras and know them very well and i have about 20 supras now i love them and i like the 7m but i'm ready to do something different and i don't realy want to do a 1jz or a 2 jzg swap i have been wanting to do the sbc swap for awhile and i now have the means to have a about a 375 hp 350 ready to drop in and need help to figure out what all i have to do to drop it in please if you can help please let me know. thanks agian
LexusTech117
108
Pullman Washington
geocities.com
Go to the Lexus V8 forums. There's a lot of good tips on there. However that's for swaping in 1UZFE, 2UZFE and 3UZFE engines. They have a whole section dedicated to the V8 Supra swap. (Not many have completed this, still very unique)
Click here for the Lexus V8 forums
Personally I'd prefer to keep the Asian motors in the Asian cars. Plus, a 3UZFE (the 4.3 liter V8) with an open exhaust sounds amazing. The 3UZFE is the engine used in the Lexus SC430. I've heard those with a Borla exhaust system and it's just music to the ears.
-David
tte
Breaking In - in progress
Northern California
Yep, and its been well known that the toyota v8 is capable of 500 hp easily.
Heard its been done in Australia alot.
cheers,
Roy
SySt
Burnsville, Minnesota
I am doing an LS6 swap into my Supra. What gen block are you planning on? Is this a carburetor or fuel injected engine? What transmission do you plan on? Essentially you will need to make new engine and tranny mounts and driveshaft as well. If it is EFI you'll of course need a different ECM and get it all wired up one way or another.
suprarich
Guest
Nov 9, 2005
2,187
ohio
That was the same question I was going to ask, EFI or carb. The carb swap is a breeze. The sbc tends to run a little too hot with our radiator so a custom or a upgrade for a 7m is the way to go. The motor mounts, tranny mount, fuel, exhaust and cooling are the easy parts. Its hooking up powersteering, air cond, and gauges in the dash that are a pain in the ass.
Use shorty block hugger headers back to a single exhaust. Duals gave a clearence issue and sound too "camaro from the 80's". The front springs are fine for the weight also, being the the sbc is nearly the same weight as our
7m. Go for it, then add a paxton to it when your done.
87centertips
107
edmonton alberta
i can't give u to much help seeing as it's just a dream for me and my dad since we have no car to put it in and it's not going in mine i got plans for that one but there is a person in www.supraclub.ca that put a 350 in his mkII i can talk to him for u at are next meet this sunday and see if he'll give u some info
supra90turbo
shaeff is FTMFW!
MA, 01440
Put a 3uzfe in it for the love of god... I heard an LS430 with an exhaust, and there are no words that I can think of to describe the absolutely beautiful sound...
You know how your car will drip water in the form of condensation out the tailpipe?
Well, that LS430 dripped sex. Pure sex. DO IT!!!
supramk3man
414
kentucky
i'm going with a carb i don't want to deal with the ecu and the pain of having to deal with the fuel presure and all that i'm useing a built 400 turbo to it i have a friend that makes driveshafts so that should be a problem. 350 block is a new one but i'm using vortex heads and going to go ahead and bore it to about a 355 or bigger just going to see what the shop says. i will be using a factory rear end from a supra i haven't fully decide on which one i have a 3:73, 3:90 and a 4:10 all lsd but will go with 3:73 if i'm going to street it much thanks for the help and please keep a eye of any one that has done this i know a long time ago i talked to a guy on supraforums that could make motor mounts that for the swap but the forums are donw so i haven't had a chance to check that lead but agian thanks for the replys
lanternman
153
MI
I love it. :biglaugh:
SnowMongoose
150
Bellingham, WA
I think he said he has had 26...
likely not all at the same time.
<lowbudgettarga and I have a dream of a supra only junkyard, which would in fact allow us to have that many supras.... for now we settle for three and a half between the two of us.>
supramk3man
414
kentucky
i have had up to 21 one at one time no joke i have them at the house i part them out with help of my father i have been at it for serval years i found that supra people always needed things just like i did and have had great luck finding cars that people gave up on and decide that one supra that is dead could still give life to many more.
supramk3man
414
kentucky
i invite any and all of you any time to come to ky i promise you will not leave unhappy if you want to see them i got them 9 nonturbos and 11 turbos and one turbo as a driver and just got one as a project as a turbo built up and then one i'm going to put the 350 in. i have sold 9 different supra that i'm not counting so i have had over 32 in the past 5 years
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
hey me and a friend of mine did a 327 swap in an 87 na auto it takes alot of beating and banging but it can be done we had to make custom motor mounts tranny mounts and a different drive shaft we also had a problem with the rear end it kept getting basically ripped out so we took the motor out and sold it then i took the body to my brothers and hes still got it now but good luck any ways "you should stick a big ass turbo on it just for the fact of it being a supra then you can say (hey its a 350 TURBO lol)
supramk3man
414
kentucky
any chance you can pm me some more details and picks of what all you did and any problems you ran into i 'm about to start puttin the motor together and the car is about ready to head to the customs shop so any insite would be greaty loved thanks for your support
