I've just fitted my sard 540cc injectors, which wasn't as difficult as I thought they would be to change:icon_bigg Basically I removed everything from the inlet manifold which allows you to pull the fuel rail out.
I'm having problems with the wiring for the 7m resistor pack though, What's got me stumped is that where the harness goes through the firewall I have opened it up to do the soldering there, but I have found 7 black wires instead of 6 that I was expecting from 6 injectors, I have used a multimeter to continuity test the wires and all 7 go back to the injector earth/negative
How can I find out where the 7th wire comes from?
