the heater is not blowing hot air. at first i thought this was due to a vacuum problem i had but after i got the vac fixed it's still not working.
my guess is the actuator at the firewall is not opening up because i unplugged the vac hose on top of it and nothing...no vacuum.
the i let the car run for a little while so it was up to operating temprature and felt the 2 heater hoses at the firewall. the hose going through the firewall (heater hose 1) is as cold as they come. the other hose (heater hose 2) that comes up from the back of the engine bay is slightly warm but definately not hot.
sorry i'm not th best at describing stuff so bear with me.
also, there is a device next to the actuator that has a vac line running into the actuator from the firewall. can that be the reason it's not working?
i pointed to the device in the pic below.
thanks
ray
thanks
ray
