im trying to figure out my overheating problem so right now im burping the system and noticed that my heater hoses by the firewall are very hot after running for about 7 min while my upper radiator hose is just warm. i also noticed that both of the hoses were hot before i turned the heater on as well. i though the bottom hose that goes into the firewall wasnt suppose to heat up (with coolant) until the valve opens to put coolant into the heater. could a bad heater valve cause overheating? maybe i should concentrate my attention towards the hoses and heating components up by the firewall rather than the front by the radiator. i replaced practically everything up front already anyways. thanks in advance!
