Heater hose delete
SIX_SEVEN_ONE
Guam USA
Wassup eryone,
Quick ?? Can I just block off the ports that used to got to the heater core?
I was gonna connect the 2 but its gonna be a pain being so close the the fuel rail. I dont want hot coolant lines leaning on the banjo fitting.
Thanks in advance!!:biglaugh:
Forgot about the other line at the back of the head.
Still tho with 7m head gasket issues and the usuall 5-6 always blown best to loop the lines and let the coolant flow as much as possible.
e30-323ti
WGTN
I will be deleting mine (1JZ)
Figure it has been fine for years with the heater valve always closed when at trackdays.
Shouldn't be any different if it's capped off.
Will also be ditching the block mounted water/oil cooler and going with a inline thermostat & big air/oil cooler.
Thus removing the whole metal tube around the back of the block.
ps. If you look at the 1JZ/2JZ coolant flow diagrams in the TRSM, the primary coolant circulation is through the block to the head (back to front) and out to the raditor.
If anything, removing the heater circuit will be promoting more coolant flow through the head.
SC61 MK3
316
FL
Loop the lines for sure, keep it moving... Especially back there were heat builds up
