On my 91 supra, the headlight motors decided all of a sudden to stop working. Both sides of all things, although the lights themselves still turn on. I have checked voltage at the motors, and they do not get any power. I know there is the headlight retract control relay under the dash and the headlight relay that I believe is under the hood. What does the control relay look like and is it above the steering column or beside it? I read on another forum that there is a ground wire that connects under the coil pack. Is this true? If it is, what color is the insulation of the wire and where does it connect at?
