My friend has a problem with his car where the headlights don't turn off. No matter what the switch is set at they are always on. We have gone through and changed the switch, the headlight relay, and the integration #2 relay. None of these had any effect. I have determined that it must be the headlight relay wire going to the ecu that's causing the problem. My question is why does the ecu need to be wired to the headlight relay in the first place, what will it do to cut that wire?
He has an 87 ecu and harness in an 89 car and I think that is the original cause of the problem. I talked with another supra owner who said he has the same setup and the same problem. Does anyone have any more information as to why this happens?
