I wired my prosports in fully tonight. I found the green wire coming out of the steering column. Well when i put the multi meter on it, it didnt do anything. So I figured i would pull power from the fog light switch since the switches light up with the headlight switch. Found a wire that suites my needs as I thought. Only problem is when I flip the high beams on it turns my gauges back to white from green. My question is were can i draw 12V thats controlled by the headlight switch to change the color of my gauges?
