Hey, hey. This morning I decided to finally put this thing together. I went to Home Depot and raided their plumbing department. I got some 1/4 in irrigation hose, some T connectors, some 90 degree elbows, and four 1/4 pattern spray nozzles with pressure adjustments. I disconnected the headlight washer hose off of where it goes into the top nose piece and routed it down to the bottom side of the front bumper. I then stoped up the loose end by bending it back 180 degrees and ziptied it in place. I then punched a small hole in it and plumbed in one of the T connectors. From the connector I ran hose with two more T pipes and two elbows. on top of the other T pipes and elbows I connected the spray nozzles.
As for wiring, you can make the washers go without the head lights up by splicing the violet/another color wire (sorry, I forgot what the other color was) from the washer button to the white with black ground wire from the cigarette lighter. This will make the pump go when ever you push the botton.
Pretty easy install, and really fun to play with. Gets the intercooler nice and wet. Now I just need a hot day to test it.
Pics when I get the time to upload them.
