headgasket and silicone
7
787m
Guest
In my service manual I noticed it said to put silicone at the front of the headgasket about where the lower timing cover goes. I bought the manual after i had already done the HG and was wondering if this is why my car leaks a shit ton of oil... I was thinking it was the front main, now not so sure. Anyone?
JDMMA70
2,550
Houston
in the case of someone elses car i saw that didnt put the FIPG down. To answer your question its a probable yes
mkIIIman089
Ohio
Depends on your technical term of "shit ton"... yes, it will leak fairly significantly from where the head meets the block/timing cover. Enough to coat the undercover, PS pump, water pump outlet, oil pan, etc. in <1000 miles.
