Header Panel Question?
DETONATION666
DECEPTICON MK3
Oct 29, 2006
333
Bethpage, New York, United States
I recently bought a kouki header panel for my 88 and a Turbo-A duct.
I wanted to have the duct on my 88 bumper and no headlight washers and hole where my supra emblem used to be.
The 90 header panel looks like "and Im asuming that it has a different corner light reinforcement than my 88s" Would the reinforcements me interchangable so I can keep my zenki bumper?
KeithH
Portland, OR
You could just fill in those holes and keep your original cap (header panel). Probably save a few bucks too.
Check out www.urethanesupply.com and get yourself some FiberFlex ( http://www.urethanesupply.com/Merch...ct_Code=5003R10&Category_Code=&Store_Code=URE ) to fill in the holes and then smooth everything out with some FlexFiller ( http://www.urethanesupply.com/Merch...uct_Code=2000-C&Category_Code=&Store_Code=URE )
You're gonna need to fill in the emblem hole on the replacement panel anyway - and then there's the whole thing about the painting.
DETONATION666
DECEPTICON MK3
Oct 29, 2006
333
Good link Ill keep it in mind...Just kinda bought it allready and I like the toyota emblem. Anybody done this before is it not possible???
has anybody done a hybrid like everything from the middle down is 89+ and the top is 87-88??
KeithH
Portland, OR
I'll hazard a guess that the panel itself is interchangeable. The supports are likely part of the car. They look identical (except for those ones with the headlight squirters).
bryanintexas
aaarrrrrggghhhh!!!!!
Apr 4, 2005
605
spring, texas
Yes, the nose piece is a direct swap. 86.5-92. If you go w/ an 89+ bumper and signals, you will need the 89+ reinforcement so you will mounting points for the grilles and 89+ signals. It bolts in.
