bout to put a metal head gasket on my 7M. it's a 1.4mm from titan. i'm also using arp head studs. need to know how many ft/lbs to use? i've seen different ppl use different amounts.
Well I guess I'm just a fucking idiot then I'll leave now.........:3d_frown:rumptis said:ARP Bolts/Studs have a torque setting they are suppose to go to if you go over that then they are trashed. The Studs that you got should have the info with them on what to torque them to.
Go by ARP specs not just whatever sounds good.
IJ. said:Well I guess I'm just a fucking idiot then I'll leave now.........:3d_frown:
Please ignore anything and everything I post.
:nuts: :weak: :dunno:rumptis said:ARP Bolts/Studs have a torque setting they are suppose to go to if you go over that then they are trashed. The Studs that you got should have the info with them on what to torque them to.
because its true, but what does it hurt to spend 30min to re-check for safety sakeMKIIITrbo89 said:I contacted ARP when installing my MHG and ARP studs. The ARP torque specs for the studs are 80 lb/ft. That is what I torqued mine to. However going above that a little won't hurt.
My mechanic told me it is not necessary to retorque after using the studs with a MHG. He is very reputable and only works on imports. I have about 700 miles on the car since the installation of the MHG. Reading these posts I was just wondering if this is something I should do?? If so why would he tell me this?
