hey guys, so i have a few minor problems i was hoping to get a little help with.
first, when the car is idleing or revving below 1300 RPM, i get a slight tapping. I uploaded a video of it, and if you listen very closely, you can hear it.
I know its coming from the head, but have not had time yet to pull out the stethascope and start poking around. it also sounds like its coming from closer to the firewall. making me lean towards a sticky injector. but i'm just not sure.
second problem, if its very cold out, or raining, my car will either idle at like 200-350 RPM, or just stall out. then, if i shut it off and start it back up again, it idles fine...then i put the engine under load again, and its right back to the screwy idle. i have checked all the connections to the Idle air control valve, intake temp sensor, and map sensor.
i have no codes (other than 42 no speed input to the ECU...so that should not have anything to do with a bad idle.)
if you guys have anything, i'm all ears
thanks,
-Trevor
thanks,
-Trevor
