Hello.
I've been enjoing my Supra after turbo swap, but no so long :-( Today I was going to set ignition timing, but i could not see any marks, so I decided to paint them in white... I put wrench on crank bolt, turned it a little, painted marks... And started the car. Yes, I forgot wrench on the bolt, so bolt flew out and engine stopped. When I returned bolt on it's place, checked marks, started car - only 3 or 4 cylinders are working :-(
So, I think some of valves are twisted (they met with pistons)... Now I'm gonna to remove head...
And finally questions:
1). Now i'm using stock headgasket, and planning to use HKS 2mm (I already have it). Friend of mine, has lapping tool, so I'm going to lap block in the car.
Have anybody done that? How to prevent laping abrasive from getting in oil system and cylinders? Will be enough just insert paper or cloth there?
2). HKS bead gasket - with 86mm cylinder bores, but my engine is 84mm (stock). Is not it a problem? HKS says that their gasket can be used with nominal bores and oversized too...
3). Cauld not you give me a link, please, that help with head removal/install (I already have TSRM and supras.nl)
looking forward your answers and advices, thank you very much.
