head re-tapping?
gmoney
supra is as stupid does!
Apr 22, 2005
97
CT
home1.myspace.com
Ok i have had my car butchered at one shop with heli coils and that isnt holding very well. So would it be possible to tap the exhaust bolts that go into the block up to a 12mm bolt as opposed to the 10mm that it comes with. I would go with an 11mm but i cant find them anywere. so I figured a 12mm would be ok but wanted the peoples advice before i went and had another shop do it. thanks
Squid699
Manic Mechanic
Chesapeake, VA
well apparently he told me wrong.......he used the US equivalent for the stock Metric size........wish he woulda gotten his story straight first. :3d_frown:
Bishop92t
773
USA
www.ma70.com
It is possible to go with a larger size, however you might find an english size easier to find and tap for. The other possibility would be to have someone build up the material with a TIG welder and tap into that.
gmoney
Apr 22, 2005
97
CT
home1.myspace.com
ill have the shop try the standard size first if that doesnt work ill have them check the heli coils maybe the shop i went to did them wrong.
