Look at the bottom of the page at the related subjects and see if you can find an answer in those threads. You might want to check fuses and relays but I'm an electrical idiot.
If you can't figure it out between these 2 pages (first one is an explantion of how to use the diagram, click next page for the explanations of each highlighted item) Then you probably shouldn't be messing with your wiring!
