head light question
dirtlord420
just here
Aug 1, 2005
371
tn
my driver headlight wont come up. the fuse is good and the other one works fine. the light doesnt come on at all. it worked before i switched motors ecu and the harness. any ideas????? cant drive with out my lights
DrakeMK3
"The Duck"
Knoxville, TN
Are you sure the motor for the headlight works?
The thing that has me is that your light doesn't even come on which leads me to believe it's all connected to the switch.
If you figure out what it is, I'd be interested to know what the culprit was.
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
You probably aren't getting any voltage TOO the headlight. If you changed harness, and thats when problem started, then check for juice at headlight bulb connection, then work your way back from there. Could be bad connections, or a broken wire in new harness. Check grounds (the over-looked wiring).
dirtlord420
just here
Aug 1, 2005
371
tn
i put my 89.5 harness in it. and i think it has a extra plug. b/c the lights works. but why would that one pop up and the light not work?
dirtlord420
just here
Aug 1, 2005
371
tn
ok traced it back all the way to the fues and am not getting power there. what could be causing this? and where is the headlight relay?
dirtlord420
just here
Aug 1, 2005
371
tn
i switched the relay, the fuse box, even the switch itself. and still nothing. i didnt think the wiring harness would have any thing to do with that. but somthing is really not right
