Last week my car developed a small knock that was very unnoticable unless you were next to a wall and on the gas and you could barely hear it then. 2 days go by and it starts getting worse and worse until i stopped driving it yesterday. It was about normal maybe alittle louder than it initially started yesterday going to work. All was fine going from work to school. But when i was going home I got off the freeway and it was LOUD. I was only 2 miles from my house so I just said screw it ill just make it home.
I pulled the valve covers off and checked the lash. Lash was actually a tiny bit tighter than spec. I did a compression check (valve covers off, dead cold, WOT, .017 Ross forged pistons, cranking motor on a low battery) I did 2 tests per cylinder.
#1 90psi
#2 95psi
#3 ~87psi
#4 ~87psi
#5 80-85psi
#6 85psi
I completed a compression check a month ago and the lowest cylinder was 145psi.
I really do believe that the knocking is coming from the head, when i pull the oil cap off the sound changes. The car ran low on oil once a year ago, since then i've been super anal about oil level always being over the full mark.
Found some brown milkshake starting to clog up the nipples on the valve covers and free standing water inside a hose for my catch can. The bottom of the oil cap is coated in brown milkshake.
Discuss. HELP!
Also contemplating a 2jzgte swap.
#1 90psi
#2 95psi
#3 ~87psi
#4 ~87psi
#5 80-85psi
#6 85psi
Discuss. HELP!
