head gasket
88-7MGTE
so im susposed to get my block from machinist on wednesday next week, and i ned to to orde a head gasget the took off the block .003 so should i get the titan 1.4mm so it wont lower my comression or should i go with the 2mm ??? titan also
thanks for any imputs ya'll
supra_ed
415
ohio
if ur doin a mild bolt-on build or a stock 7m, 1.4 would be fine. if ur doin a complete build, which it sounds like u are, get a 2.0. ive personaly used both tms gaskets and have no complaints. GET YOU CYLINDER HEAD CHECKED!!!!
88-7MGTE
according to titan themselves, titan contracts cometic to make all of there head gaskets so basically they are the same gasket. as for thickness- 1.4mm would be fine for mild boost or stock bottom end. for heavy mods or a built engine, u can't beat a 2.0mm. according to stillen a 2.0mm would lower compression down to about 7.8:1 on a stock 7m- which means more boost can be safely ran. ive personally used both (i swear by tms head gaskets), just a matter of how much power you are planning to make. but u should definitely get the head checked while its off.
i got this from a different thread supra ED and i think you wrote this
but i also have read that lowering the compression its not good, why? for some reason i dont remember, but thats what they say
supra_ed
415
ohio
if u lower compression too much, u will kill performance. that's why na-t cars are soo badss with just a little boost. higher compression also means quicker spool. but for a street car, lower compression for safety (detonation) and run more boost. if ur around 8.0:1 (8.4:1 is stock for turbo) u will never notice the difference. why i got my head milled, and it was pretty warped, i went to a 2.0 tms gasket and there wasn't a change in performance- just piece of mind.
91T breezen'
ROMNEY/RYAN 2012
Apr 4, 2005
1,149
NOYFB!
I just happen to have a 'Brand new in box' Cometic 2mm,:icon_razz I will sell you for $175.00, shipped.
Interested? PM me.
Tom
88-7MGTE
Interested? PM me.
Tom
a little 2 late i bought one right away from titanmotorsports.com
and i bought titan insted of cometic i'v been reading on tem some,
and just didnt feel right to go with cometic
but a good price if knew earlier i would bought it :(
