Head gasket
s383mmber1
3,614
Somers New York
Hey guys---im going to be working on the engine soon anyways, so i was thinking that i was going to re-torque my head gasket.
im N/A
What should i re-torque it to? Is it a good idea to re-torque? Any "side-affects"?
thanks a bunch!!!
~William
shaeff
Kurt is FTMFW x2!!!!
10
Around
i re-torqued the HG on my GTE when i first got it. (hadnt enough cash for a MHG at that time) no side affects. some say you can "squish" the headgasket, but i havent heard of anyone actually doing that.
basically, following the TSRM order, you crack one loose, then torque it to 72ft lbs, and continue to do the same for the rest of them, making sure to follow the order. :)
-shaeff
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
I stepped my turbo up to 77lbs, about 10 pounds at a time. My hand was tired when I got through. Tried to keep the pressure pretty even all the way, rather than a 20lb difference between studs in the process.
