head gasket
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
xr666;1382497 said:
hi iv just done my head put all back together it is hunting badly on idle ? help
Read what you typed.
Then go back and correct 89% of what you did, so the rest of the world can understand. If you can register your account, you surely can type a complete sentence.
radiod
1,342
Abbotsford, BC
Check codes, check ignition timing, and I don't know if the car would even idle if the timing belt was a tooth off on either of the cams or crank, but check that too. 90% likely you'll find your problem in one of those 3 places ;)
