This is regarding the 1jz head. clearly cylinders 2 and 5 are the smallest ones on the exhaust side of the head. what kind of difference do you think opening up the ports on just the exhaust side and port matching 2 and 5 to the new size would affect. power range, and overall output?
Couple things I am aware of.
(1)you cant make the ports bigger than the manifold they are dumping into the reason the head ports are smaller than the manifold is so that the exhaust gases will have less ability to reverse back into the cylinder.
(2)because the 1jz is a short stroke motor (not super torquey) you cant go too large inside the ports because you still have to try to maintain good port velocity to maintain good spool up.
I might be wrong on this but the real restriction on the 1jz head is mainly the exhaust side ports. and allowing more flow on that side so that the motor can expell more burnt exhaust gas per exhaust stroke, so there is more room for fresh air per intake stroke.
So my plan is to have all the exhaust ports ported out just a bit(probably gasket matched) on all 6. but leave the intake side stock. do you think this would extend the power range? or do you think the intake side HAS to be done also?
