i just changed the hg on my na 2j to the gte hg. i got brand new head bolts and a brand new stock gte hg. i got the mead machined and block cleaned. cleaned all the head bolt threads in the block. lubed all the head bolts and followed the toyota instructions for a gte on torquing the head. 25 ft/lbs then two 90 degree rotations. when i was done with torquing the front head bolts were around 110 ft/lbs. and the rears were at 85. im a little worried something is wrong. and i dont want to retorque because they are torque to yield bolts. got new washers with bolts too. should i tear it apart again. or just see what happens?
