have you ever tired steel seal?
enjoi.this
Formerly ChrisC
Aug 18, 2008
674
Kelowna, BC
That guys positive attitude with redneck stylin' sure makes me wanna buy that. yes sir ree bob! :sarcasm:
Now thats something I would use on my winter beater tercel if it happened to pop a hg. I doubt its works as well as it seems. deff couldnt see it working on a severly blown hg tho..
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Think about what they are claiming for a second.
Here's this liquid, that will, without solidifying, contain thousands of PSI from cylinder ignition inside your engine. How does the physics on this work again?
Hell, why not build the entire engine out of it? It's about the same level of realism.
lewis15498
Don't blame ebay cheapass
Sep 28, 2008
1,397
Raynham, Massachusetts, United States
A If it stays liquid, it wont fix anything.
B If its able to clog a hole in a head gasket, then its going to clog everything it goes through.
Headgasket repair elixers are usually somewhere between A and B giving them the abillity to clog your cooling system without fixing anything.
So the answer is no, it wont work.
Guyana00
Droppin that JZ in soon!
Apr 18, 2007
1,208
Brampton, ON
^ That's a good one!
Anyways, I think it will clog and quickly fuck the engine up. The HG job on those vans aren't so bad. Probably around $500 for you to GET IT DONE AT A SHOP. Yup, they do all the work, you have to supply the materials, few gaskets.
Cheap.
RiyadYar
384
NY
this was from a while ago i told him but he was so desperate he just bought a bottle and it didnt fix anything it might've if the leak was very small because it trns into a vaseline like paste that clogs any holes . we ended up junking the van nd buying another because we found one with hg job done already for cheap
