Haunted Dome light
vdragonmpc
tireflaminrumpshaker
Apr 11, 2005
300
Colonial Heights
www.joncjennings.com
Im having dun with my interior dome light.
It stopped working and has generally been forgotten. I got ahold of a clean one and swapped it out. I changed the bulbs and then went and got new ones also as nothing worked.
Today I go outside and the left one is lit. I cant get the right one to light so I swap bulbs. I kid you not now neither work again. I pulled it down and checked the connection. Everything seems good. I have ignition key lights, door lights, vanity mirror working. Just cant get the dome lights to come on with the door opening or the switches. *security light in dash shows the door open. Alarm works fine. Open door mayhem ensues.
Why would the light be on this morning? I changed nothing after giving up last night
Chris
the ground that is up there is riveted in and get corroded with rust. Need to drill it out and create a new ground.
ALso if the door switch is bad those wont turn on either. If the light on the door panel comes on then the door switch is good.
