I can't get it open inside neither with the key and I'm getting water inside where the spare tire is.I got the 3 pieces tailights and it's a pain in the ass to take out the tailights.
blacksupra said:I can't get it open inside neither with the key and I'm getting water inside where the spare tire is.I got the 3 pieces tailights and it's a pain in the ass to take out the tailights.
Brewster said:For some reason my key would'nt work in the passenger side door or the hatch. I actually bent the key trying to open the hatch. But my lever worked.
Maybe there's some slack in the cable that connects to the lever. Try pulling on the cable if you can get to it.
Yes7MGTEJoe said:Interesting; does anyone know if the mk3 came with a valet key?
The master key works in every lock. The sub-key will not work in the glovebox.
To protect things locked in the glovebox when you have your vehicle parked, leave the subkey with the attendant.
Since the doors can be locked without a key, you should always carry a spare master key in case you accidentally lock your keys inside the vehicle.
