Has anyone used this IC?
born2drv
1,199
Burbank, CA
Link doesn't work for me. Anything with a core size of 24" width and 4" thickness will fit. 4" takes a little bit of modifications, 3.5" or 3" fits with little to no modifications.
whudafux
Formerly dcrusupra
Jan 5, 2006
1,034
Cullowhee, NC
Link works for me. But yea its a 24x12x4 IC for $220.
24"x12"x4" intercooler, bar and plate design, with 3" inlet/outlet. Universal fit for many cars, brackets not included. 30.5" overall length.
born2drv
1,199
Burbank, CA
You have to be logged in to view it.
It should fit, you might have to relocate the coolant tank or horns. I have the same size one.
hot dayam mk3
149
^ i have the same size for my supra.... but had to remove it due to my 57 trim too small to fill it up.
C.44
164
Behind the keyboard...
I've seen a lot of these threads lately aswell on SM as on SF. And one question always comes to mind... Since most of us still have their stock bumper, the upperhalf of those IC's is just blocked by the bumper.
Unless you've cut/modified/replaced the original bumper, the upper half just retards throttle response.
Isn't it true that a IC that'd just half as high, but maybe a tad longer would be more effective ? As the whole IC gets cooled down and not just the bottom part ?
Is that making any sense ?
born2drv
1,199
Burbank, CA
I actually got an IC that was a tad longer and shorter... it was 26" wide and 10.5" tall x 3.5" thick. It did not fit, too wide. I still have it in my garage if you wanna buy it :)
the frame rails get in the way.
although the top half is covered, some air flows threw it, and it still functions well to transfer the heat out of the air, although not with maximum efficiency. Anything with a larger cross-sectional area will perform better then a smaller area, whether there is marginal or vast amounts of airflow, it's better then nothing.
Eventually I'll hack up my bumper and reinforce it another way or something when I get my body work done and put a custom bumper on it.
