Has Anyone Used this Fuel Setup?
radiod
1,342
Abbotsford, BC
Before anything else, what are you running for electronics? The Lexus AFM mode won't work with 680s. You'd need to run MAFT Pro or full standalone to be able to use injectors that size.
They have made pigtails to adapt the injectors to the stock harness already.
Elie_Kaze
86
Lethbridge
Well I was thinking of running an MAFT-PRO or VPC. The injectors are Bosch injectors. Will the injectors be a true plug and play?
Elie_Kaze
86
Lethbridge
Well, the things that had me interested were the injector clips. Are Bosch injectors not quality? Will the clips be truly plug and play?
What if I plan on upgrading injectors in the future? Would this be a good setup to run?
radiod
1,342
Abbotsford, BC
Canuckrz;1858243 said:
The upgraded fuel rail is useless bling at that injector size. Get some actual quality injectors and pay less.
That's what I was thinking too, but I wasn't 100% sure. From what I remembered our fuel rails are pretty darn awesome from the factory. Rather than buying one like that if you want to dress it up you can just paint/powder coat/etc the stock one.
The clips look right. In reality it's not hard to make the adapters. Finding pre-made adapters typically isn't hard either if that's not your thing.
Elie_Kaze
86
Lethbridge
The question is... can I run AN fittings off the stock fuel rail without having to drill or weld some on? I would like to replace some if not all of the stock fuel lines with AN fittings and braided hose.
I no idea how to make adapters for fuel rails. Would you recommend these adapters even if I didnt buy this fuel rail or injectors? They do sell them seperately.
Elie_Kaze
86
Lethbridge
I hear what you guys are saying, but for someone like me who is new to this all it's still confusing. So the M12x1.25 fitting is the adapters I need for both the rail AND the FPR? The rail only uses the same thread pitch on every port?
What does this equal when looking for -AN size?
Turbo Habanero
4,229
Tucson,AZ
I will admit it is pretty confusing if you know nothing on how to get the correct sizes but like anything taking the time or finding the key that best suits you to understand, can take time...
Hvyman that was pretty helpful thanks.
Google is your friend ;). Anything your wanting to know about an is within google on other forums.
I learned everything this way and now using an fitting is like eating homemade cake.
