has anyone tried the Mishimoto radiator fans/shroud on their setup?
dbsupra90
toonar
indiucky
yeah, just looked that up. not super impressive imo
CFM: 933.5
Fan Diameter: 280mm
Fan RPM: 2095
Number of Blades :10
Current: ~8A
Volts: 12.25V
Amps: 5.7
Velocity Ft/Min: 724
Inlet Pressure While Tested: -0.04
Air Temp While Tested: 62.6 (degrees F)
Apr 6, 2005
339
Alpharetta, GA
Even if that's the spec' for a single fan, then at <2000 CFM total those fans are definitely not impressive at all. Hopefully the OP does not participate in any spirited driving, AC non functional, not automatic, doesn't get stuck in stop & go traffic in the hot climate of Florida. Otherwise, he *may* discover the possible poor choice of this electric fan setup.
dbsupra90
toonar
indiucky
on a budget- taurus or durango fan setup. cheap and effective. and they move a ton of air.
no budget- custom shroud with spal fans
in between- id look at zirgo or ffd. i have the ultra performance zirgo 12's (no longer available) and they work awesome. plus they have a lifetime warranty.
http://www.thehoffmangroup.com/zirgo/product.lasso?prodinc=coolingfans
ffd fans- local guy has them on his car. they seem to work pretty well. altho i think their numbers are a tad inflated.
http://www.ffdynamics.com/products_ultracoolingfans.htm
kabanimk3supra
kabanimk3supra
Apr 11, 2007
511
oklahoma
is there a certain year of taurus or durango, or is this something that will need to be modified to fit?
